fuel. not simply vapor, or smell of fuel, but actual fuel. sorta like along the lines of a bad fuel pressure regulator letting in additional unmetered fuel.
if you unplugged an injector on the rail then you should have had a definate misfire/stumble/poor idle. i did not see that in the vid, so check the cold start injector.
df
