How about measuring the voltage ?
If this car hasn't had the battery replaced before you are due.
There is a glass eye on the battery that tells you its condition .
I assume you mean its not turning over.
You can get a batter for between 110 and 200 in the US .
Don't use battery backup when changing a battery in these cars
it blows fuses.
You should register the battery after installation.
The cheapest way is to get a coding setup which will give you diags and the ability to code.
