Bimmerfest - BMW Forums - View Single Post - First time BMW owner. Just purchased a 1990 525i. Help?
Old 08-29-2012, 09:08 PM
TommyD525i TommyD525i is offline
Mein Auto: 1992 525Ii
Just wanted to add a couple things here. Do your tune up and change ALL fluids.
However!
I don't remember if you have a auto or manual. If its auto I wouldn't mess with it or drain anything out of it. They are notorious for failing after a fluid change! If it's manual then definitely change fluid.
DO go to www.bmwe34.net
It's full of awesome info. Ask people on here when you get confused. And get yourself a E34 Bentley Repair Manual (amazon it). It E34 owner's bible.
If you want to clean everything in the inside of your engine I would suggest researching all you can do with SeaFoam. It's amazing stuff!
Also the front control arms are renoun for going bad. The car will shake terribly bad when you hit the brakes at 50-65ish mph. That's how you'll know when those are shot. In fact check all parts in the steering system.
And check shocks too. All you need to do is push down on one corner of the car at a time. It should feel very stiff and should have very little give. If you can push it down more than a fat inch or you can rock it, then you shocks are toast.
