Bimmerfest - BMW Forums - View Single Post - What to do after buying an E36.
Old 08-30-2012, 10:50 AM
The Tick's Avatar
The Tick The Tick is offline
Mein Auto: E36 325i
Originally Posted by ZeGerman View Post
Replacing the entire cooling system is what I'd put at the very top of my to-do list.
Ok, I will.
Originally Posted by jonesin View Post
Tranny fluid
brake fluid
diff fluid
power steering fluid
cabin micro air filter.
Then the whole cooling system:
fan, rad, expansion tank, bleeder screw, thermostat, thermostat housing, upper & lower rad hoses, water pump, rad cap, and if needed the fan clutch.
The fan clutch is the one component that can fail and not be an immediate catastrophe.
Then there are all the suspension bushings, the control arms, the tie rods, the bearings, the reinforcements for the rear shock mounts and the front shock tower reinforcement plates.
Get through all that, then we'll start going over the rest.
I even need to replace the radiator? Why? does it get clogged up?
Cars
  • 2001 Dodge Ram 2500 Cummins Diesel running 411hp and 932ft/lbs (Current Daily Driver and Workhorse)
  • 3 BMW's (1 E30 325 and 2 E36 325's), 2 Audi's (B5 S4 and B8 A4), and 1 VW (MKV GTI) (All Sold)
