Bimmerfest - BMW Forums - View Single Post - How about a logical answer to a window problem
Old 08-31-2012, 08:12 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x1,E30x1, F150
Originally Posted by Damorava View Post
I removed the motor out of its position to check it by itself. By having the motor in my hand and connected to the power, it behave the same. It just make a couple of turns.
Explain "make a couple of turns"? Is that all it will do with power jumped directly to the motor? It should continue to run as long as there's power to it if it's not meshed with the regulator gear. If it only makes a couple revolutions and stops, the motor is NOT ok.
Thanks for searching! Welcome to the fest!
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 Forum & New Member Intro Forum Mod-
Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426
1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
