Bimmerfest - BMW Forums - View Single Post - 533i questions
Thread: 533i questions
Old 09-09-2012, 01:28 PM
Ixieboy Ixieboy is offline
Mein Auto: 84 533i
Originally Posted by south26 View Post
It should go up when you turn the radio on. with another person turn on the radio and have a person listen to see if they hear the motor turning. It might just need a new mast. The masts have a bad habit of getting stuck. If that is it you need a new mast. You have to remove the old one before buying a new one because there are 2 different kinds of masts. One has teeth and the other is smooth. You remove it by undoing the 10 mm bolt that is holding the mast in. Then tunr on the radio and pull up on the antennae mast at the same time. This should get it out. You put the mast in in reverse of taking it out.
Andy
well, it does have an alpine stereo in it, could have been wired wrong as well. do you perchance know which wires are for the antenna on the dash side?
