09-09-2012, 06:01 PM
Steve M.
Mein Auto: K75RT
Dealer Work done
The dealer put on 2 new tires, changed engine engine oil, gearbox oil, fork and final drive oil, brake fluid, gearbox and shaft lube, fuel filter, air filter, spark plugs, safety check, state inspection, replaced rear brake pads and crankcase breather. Sound like a value?
The crank case cover refers to the one in front (not the one with "BMW" on it), which they said is a big job to work on, and has only sealing compound, no gasket. Watching it for now.
Appreciate your advice. Thanks.
