Old 09-11-2012, 01:17 PM
Wertles Wertles is offline
Yoda with a library card
Mein Auto: 1999 M Coupe
Originally Posted by HANSONCLN View Post
I just picked up a 99 m with 42000 on it clutch grabs 1/16 0ff the floor is there any adjustments that can be made i bleed the system and no change
The only adjustment is a plastic screw on the footwell behind the pedal. If you can screw it in, that will give you a little more room. If it is all the way in, you may have other issues that require a proper bleeding of the slave or more extensive repairs or replacement.
1999 Boston Green M Coupe
2002 Z3 2.5 Automatic Roadster
2013 Ram 3500 Crew Cab Dually, 850 ft/lbs torque, stock and staying that way
1995 318i spray paint red, 170,000 miles and climbing
