Old 09-12-2012, 01:22 PM
FenderBender's Avatar
FenderBender FenderBender is offline
Needs Boost
Mein Auto: Red Sled
Hrm, not the problem. Must be fuel pressure, I'm going to get a T connection tomorrow and test pressure with it running if I can.
You can see in the video below, it seems to run pretty well with the vice grips on. However, I had to jump the relay to get the fuel pump under the car to run, is it only supposed to run while the car is running? Confused here because I'm pretty sure it was running all the time with the key on last night. And you can see that when I remove the vice grips, the car dies. This is with the new FPR.
Another tidbit, with the fuel pump jumped, I can hear fuel going right back the return line, normal?
Turbo Build Here
