09-14-2012, 09:57 AM
Mein Auto: '03 745Li
Originally Posted by gmcclintock
I would like to change out all my bulbs but when it comes to HID I'm confused. samadkins29's guide does not mention low beam or high beam bulbs it just talks about foglights which is why I'm a bit confused. So my question is what do I need to order if I want to replace my low beam/high beam headlight bulbs, wattage is a big concern for me so I'll need to know everything. I'm currently looking at these but I don't want to order the wrong thing can someone help me out? Thank you
The reason those are not mentioned is because your low beams are already HID (D2S bulbs) and you should not put HID in your high beam "flashers". The real high beams are still using the low beams, just tilting them back up.
