Old 09-15-2012, 02:09 PM
BigDeep1's Avatar
BigDeep1 BigDeep1 is offline
Festaholic
Mein Auto: 2011 535i Sport
Originally Posted by voMacK View Post
Hi,
I'm considering a bulb exchange in my F10. I would like to ask you about this picture: https://picasaweb.google.com/PHARMDP...48808528138674
What's the proper lenght then? Thank you very much
Hey bud. That link didn't work, but if I were to guess, you may be referring to the trunk bus bulb. From a Sylvania chart I found, it should be the 4311 bulb, which translates to 39mm; HOWEVER, I found that the 39mm LED bulb was too short and would not fit no matter how much I bent the housing clip.
The length to buy is the 42mm. The 42mm LED bulb I bought seemed a tad loose when put in that main trunk light housing, so I bent the clip in a little (give a snug fit).
Best wishes!
2011 535i Sport (Prem 1, 2)
