Old 09-16-2012, 07:00 PM
chagrin chagrin is offline
Mein Auto: M3/X3/XI
Once the headlight is open, remove 3 T25 screws that hold the trim and bezels inside the headlight assembly. The next step is to remove the corner lens (regardless if you plan to paint them) and then the rest of the headlight trim and bezels. The corner lens is hinged inside the headlight assembly - you simply need to unfasten a retaining clip and then it swings out for easy removal. I then uncliped the corner lens from its bracket and painted it with chrome paint.
Name:	Lens removal.jpg
ID:	342259   Click image for larger version
Name:	trim & bezels.jpg
ID:	342261   Click image for larger version
ID:	342262   Click image for larger version
___________________________________________
BMWs currently in the garage: VF570 E46 M3, E46 XI Touring, E83 X3 "M" retrofit
