Bimmerfest - BMW Forums - View Single Post - Devastated!
Thread: Devastated!
Old 09-17-2012, 03:13 PM
bayerisheteknik bayerisheteknik is offline
Mein Auto: ...
Originally Posted by pmpn8ez View Post
Wheel balance should help. It will let you know if your tire has a flat spot or bends on the wheels. You would also feel most of the vibrations from the front just cause it would cause the steering wheel to vibrate.
thats where i feel it at the steering wheel....i just checked my PSI on wheels and back tires since they are 275/35/20 i had them at 41PSI but went down to 40PSI and fronts i had them at 37.5PSI but went down to 35PSI....so will see tommorow and if thats not gonne fix it than had to take the tires for balance.....
