Old 09-17-2012, 06:46 PM
drivinfaster's Avatar
Mein Auto: rescued bmw's
i fail to see how removing the vacuum to the fpr will make it run better....unless you are running on very low fuel pressure. in which case, a new fpr will probably not be the proper fix for it.
i would check your fuel pressure reading and see what the reading is compared to spec. if low, then replace the pump and fuel filter. like sneakers and laces, they should go together.
df
