Thread: Z4 Roadster (E85) Xenon light glitch
Old 09-18-2012, 07:53 AM
imz4n's Avatar
imz4n imz4n is offline
Z ENTHUSIAST
Mein Auto: 06 3.0 si Z4R
I had the same issue with 2006. I found that by turning the lights off and then pack on via the switch the lights would come on. I got dome input from the group I run with and was told to do a power reset. Remove the negative terminal from the battery for 20 min. and then reconnect it. Be ready to turn your alarm off if you have one and you will need to reset your radio stations. I do not know why, but, I have not had the issue since and it has bee 2 years. My $0.02 worth. Try it before you spend cash.
