Could you isolate which side exactly is causing the vibrations. Front will vibrate the steering wheel and rears would vibrate your seat cushion. From there see if you could determine if it is passanger/driver side. Pull that wheel off and inspect for any wheel damage or maybe even a tire out of round such as a bubble. Replace the wheel with your spare and drive it around and see if that solves the issue. Start off with the minor solutions and if doesn't work then progress.
2004 BMW 745Li e66
22" Beyern Mesh
Eibach Springs
Spacers 20mm Front 30mm Rear
Akebono Brake Pads
JL Audio 500/1 Amp
2 Type R 10" Subwoofers
