Bimmerfest - BMW Forums - View Single Post - 94 318is Turn signal issues
Old 09-20-2012, 02:58 PM
DJNaviT DJNaviT is offline
Mein Auto: 94 318is
Hi,
Thank you for your advice. I feel you must be correct about either connection being loose or the turn signal lever might be going bad. It might be acting up some or the other reason. I will check the connections and the turn signal lever.
I will definitely update you as soon as I get to the root of the issue.
Thanks for your advice again.
