Also tip of the day you can use a generic elbow racing intake on 740s the trick is hooking up the oxygen pump as at idle the MAF sensor needs to read the extra 02 from the pump or CEL will light up I got mine on Ebay a place called racing intakes $50 including shipping the plugged whole needs to be unplugged run rubber hose from pump to hole on intake got rubber fittings and hose at of all places PEP BOYS well NO CEL and runs great next will modify stock air box to fit over intake to get cold air in.
