Old 09-21-2012, 06:45 PM
cvx5832 cvx5832 is offline
Mein Auto: 325Ci, 325Cic, C300
Sorry, forgot to mention look up Yelp for reviews on Alignment Services. It seems those that have complained did so because "they were rude". And while i noticed some of that, I personally don't put importance on politeness with an alignment job, so long as the job is done right, and the "final values" report confirm that. Drives better too. They're reasonably priced ($80 for a four-wheel alignment) and have the latest equipment. The location looks dodgy until you roll into his shop. Not directed at the OP, but if one were the mamby-pamby type this probably isn't the coolest place to check out.
I don't usually give recommendations (on anything) which is why I'm trying to provide as much detail as I can. Do your own research and you will be fine.
