Bimmerfest - BMW Forums - View Single Post - 98' 318Ti Gearbox Problems
Old 09-23-2012, 04:25 AM
70simple 70simple is offline
Mein Auto: E36 318Ti Sport
Help Please!!! .....my 98' E36 318Ti recently got stuck in 3rd gear (manual) & was told by my local mechanic it required a replacement gearbox. After being quoted around 400 odd to have it replaced, a mechanic friend suggested that we could do it ourselves.
After through research & being told that the manual gearbox was common across all the engine sizes & models in the E36 range, I plumbed for a low mileage box from a 96' 325, from a car breaker. Upon fitting we have discovered that the selector is shorter on the replacement gearbox, than the one taken off the broken gearbox & that the old one won't fit either.... The gear shift keeps hitting the top of the centre console or doesn't go into gear at all!!!!!
Can someone please enlighten me as to whether the transmission tunnel or gearbox on the Compact is different from the other E36's in the range or whether there is a difference from the 96' to 98' models?????
