Old 09-25-2012, 08:26 AM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Originally Posted by kskane View Post
Boys, I need some help. While I was about to bolt the new gasket in, I !@#$#@#@!@#$ the first screw on torque.
WHAT torque do the bolts on valve cover gasket needs to be? I read somewhere 7ft-pound and I was bolting it to to 7, but cracked/ripped the nut from engine assembly (don't you laugh at it ). Much to my luck, that screw on the engine is not part of the engine (now I will have to ask the $stealer for replacement and car is going to be out of action for few days). So please help with torque values.
Also, while I was changing the gasket (still am with the car in garage and engine open with missing bolt), I checked the spark plugs and they are NGK. I have attached picture of contact points. Do you think I should change it?
I would. This is a while you are at it type of thing. BMW does recommend new plugs every 100K, so you would be following their specs. Make sure you are using an accurate torque wrench.
