Originally Posted by rcatank
does any one know what 19 does? its on the charts, and there is a fuse... but no description...
If you are referring to the chart below...F19 is a 5 amp fuse that is in-between the ignition switch and an unloader relay terminal 15. If the space is empty on your car...then it is not required. Here's a link to the online WDS that shows what is in-line with F19:
link to WDS Fuse 19: http://wds.spaghetticoder.org/en/svg...10.svg?m=e3902(you may need to "click & hold" your cursor to move the diagram (at the link above) up/down/left/right to see everything...or you may have to use another keyboard short-cut to enlarge or decrease the diagram so that you can read it...check your VIEW pull down for keyboard short-cuts to ZOOM-IN or ZOOM-OUT)
K93 = terminal 15 relay location in trunk
Q {BMW CCA Member # 191509}
(SOLD)
