Originally Posted by eastside328
Does anybody have any information on how to make the seals last longer other than just using the rubber protectants? I'm in particluar talking about when you have the car in your garage. When the top is in the up and locked position it is crushing those gaskets when there is no need (ie not raining).
The same is true for door frame seals and trunk seals. All spend a lot more time closed than open--even more so than the top. Given regular care, none of those collapse from spending more time crushed than expanded. The top seals should be no different: Opening the top periodically to lubricate/protect the seals should be more than sufficient to keep them from taking a "set."
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff
N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
