Bimmerfest - BMW Forums - View Single Post - 2008 650i Slotted/Drilled Rotors (ADVICE NEEDED)
Old 09-26-2012, 09:00 PM
Yorgi's Avatar
Yorgi Yorgi is offline
I recommend OEM rotors because they are a semi-floating 2 piece design (aluminum hats with steel rotor rings) but they go for about $180 each. You get what you pay for though, OEM is the best quality on the market.
Drilled look cool so if you are going for looks the best drilled on the market are made by StopTech and are available at TireRack. Here is a post with the links.
'04 M3 - track
'06 650i Cab - daily driver
'02 Highlander - kid hauler
'01 330Ci - winter beater
