Bimmerfest - BMW Forums - View Single Post - New BMW owner and need some advice
Old 09-27-2012, 11:46 AM
Originally Posted by SirFatCat View Post
Mechanic says engine compression is getting into the cooling system.
You probably do not know how many times this has happened in just the last six months alone ... so ... I painstakingly created this set of comprehensive links for the E39 crowd (most of which apply to the E46) just for folks like you!
- Summary advice to provide users who suspect a major engine repair due to overheating (1) (2) (3) (4) & how to test an engine for a blown head gasket, cracked heads, a warped block, stripped head bolt threads, cam seizures, contaminated bearings, coolant hydrolock, or piston, ring, or valve damage (1) (2) & what are the major factors in deciding whether to rebuild the engine, replace the engine, or sell the car (1) & a DIY for replacing the I6 M54 head gasket (1) (2) & replacing the V8 M62TU head gasket (1) & why these engines are so prone to heat-related damage in the first place (1) & welding the crack between cylinder #3 and the water jacket on the exhaust side (1) & what engine swaps are most recommended (1) (2) (3) & where to obtain a new or rebuilt head (1) replacement short block or long block (1) (2) & how to lift & remove the engine (1) & the most recent real-world results from the last 50 people faced with similar blown engine problems from which this advice came from (1) (2) (3) (4) (5) (6) (7) (8) (9) (10) (11) (12) (13) (14) (15) (16) (17) (18) (19) (20) (21) (22) (23) (24) (25) (26) (27) (28) (29) (30) (31) (32) (33) (34) (35) (36) (37) (38) (39) (40) (41) (42) (43) (44) (45) (46) (47) (48) (49) (50)
If there is a question you have that is "not" covered in these threads, then please let me know and I'll make a link to the solution you find.
