Thread: Wagner IC
Old 09-27-2012, 08:07 PM
GreekboyD GreekboyD is offline
Mein Auto: 2009 BMW 335d
Originally Posted by Snipe656 View Post
Dyno runs can be a bad way of determining things, well unless the heat soak is just REALLY bad. Reason being is even with those fancy fans they use it is really hard to emulate the real world effect wind has.
I do not see an IC as an avenue to HP but as an avenue for getting the delta you are speaking of, which ultimately should help with maintaining HP across usage. Then even if these cars do have a poorly efficient factory IC it still is nice to look at the data for aftermarket options because not all IC cores are created equally too.
I am not knocking the option for one, just curious to see the data people have collected to prove both the need for one and how much each aftermarket option help solve that need. Since I do not frequent the other BMW forums enough to know about all options/issues for the 335d then just figured asking here might result in seeing where others have already done all this.
Well said. Let's see what data Wagner shows us with their IC.
