Old 09-28-2012, 05:47 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
To keep the tie rod end from spinning, lower the car until you can reach it with a jack. Put the jack under the tie rod end and raise it just enough to stop it from spinning. Use a 17mm socket to remove the nut. CLEAN the nut so that the socket will fully engage the flats before you go any further. Use a 6-point socket if you have one.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
