Bimmerfest - BMW Forums - View Single Post - noise from the rear
Old 09-29-2012, 01:48 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E39 6 Speed
Originally Posted by chrisbmw318i View Post
Hello I. Have this bmw318i its 1998 manual trans just changed center support bearing was shot but noise still present its like "wow wow wow" whence over 30 mph. Turns do not affect noise there is no clunking sound when taking off everything whitout play help what is it?
Did you align the driveshaft the way it was prior to removing? If you changed the csb and didn't align it the way it was it is not balanced correctly. Also check your flex disk, it sits on the trans output flange. It gets worn out and cracked after years of driving. If there are cracks on it it will start tearing apart.
