528 Jumping out of 1st
Hello all. This is my 1st post.
I recently bought a 86 528E. The speedo says 300k and is stopped. Ha
The car was shifting OK when I bought it but the shifter was very very loose. I installed new front and rear metal console mounts. The car now will not go into 1st gear. I can some times make it go in 1st gear if I push, fuss, grind, baby it and let clutch out slowly. Gear oil has been changed. I had a German mechanic put the car up on his lift. He adjusted it and same problem .......... Any ideas, is it still a adjustment issue or serious tranny problem.
Thanks for looking.
JJT
Reason: Better description.
