Bimmerfest - BMW Forums - View Single Post - Massive/annoying belt chirp when cold
Old 09-30-2012, 09:54 PM
1995i540's Avatar
1995i540 1995i540 is offline
Founder @ Maintenr
Mein Auto: 1995 540I/6
If it chirps when you are not turning the wheel, it could be tensioners like the dude above mentioned.
Could also be a simple case of worn belt/tension loss via a loose tension bolt that keeps tensioner in place.
It could also be a failing component on the drive train, so make sure you take a look at it asap before your belt seizes and causes $$$$ in damages.
///////////////////////////////////////////// E34 Addicts
Founder @ Maintenr. Take control of your vehicle maintenance.
