10-01-2012, 06:32 PM
Major
Mein Auto: 745 li
Originally Posted by SFbay
So it's not showing "P" on the dash??
So what is it showing then? Blinking gears?
Well first try emergency cable release. It's located near diagnostic port. Remove your metal key and open that small plastic cover, then pull the red handle, it will put your tranny into neutral gear manually. Then it should start. Also read tranny errors.
Thats the first thing i did. Emergency gear release doesnt tell computer that the car is in neutral there is no errors on the transmission they check that as well
