Old 10-01-2012, 10:12 PM
Technic's Avatar
Technic Technic is offline
Test... 1, 2 ,3
Mein Auto: 2012 M3 - 2010 CC
Originally Posted by virus86 View Post
I wonder if you can convert the snap-in adapter port to a standard apple/usb port. I'd like to keep a beater itouch in there and have the already installed usb port to charge my android phone.
You will need to unplug the baseplate and plug another OEM USB port in there, the cable connector coming from the Combox should match the new USB port. Item #4 should do just fine:
If the connector does not match then you may get an OEM extension cable from the Combox secondary port to wherever you want to place that USB socket. That's the same OEM extension cable that connects the primary USB port to the Combox.
Where would you place that new OEM USB port is up to you.
