Old 10-02-2012, 11:01 AM
Oceans10's Avatar
Oceans10 Oceans10 is offline
Mein Auto: BMW 535i + 535XI wagon
Headlight, Xenon bulb replacement
Just replaced a burned out headlight xenon bulb.
BMW wanted almost $400 to replace it ($240 for part, plus $130 for an hour of labor, plus tax).
Instead I went for Option B and bought the bulb for $40 on ebay. The oem bulb is an Osram D1S with 4150k brightness.
I bought a DOT stamped Philips XenStart D1S Xenon from
oemxenonparts, 4300k, and it matches perfectly with the Osram. No need to replace both.
Installation required removing 2 top screws and 2 at the bottom, you need an extension to reach down. The headlight unit then slides forward and you wriggle it loose and tilt out of the cavity. A plastic cover on the back drops down to expose the bulb. turn it 1/4 turn and remove. Unplug the wire, take off the neckless type bracket, like a collar, and clip onto new bulb. Install.
Whole procedure took 20-30 minutes but this was a first time experience and I was figuring it out on the fly.
The 2 lower screws are tricky to refasten. You need an 8mm socket with magnet at bottom to hold the screw, or a nut driver with long shaft, 6 inches or so. I stuffed a little duct tape inside to make it sticky. Did the job.
Audio: Jehnert Flatline speakers, Mobridge M1000 DA2 prepro, Helix P-DSP, Zapco Z-150.6 amp, CIC iDrive upgrade
Performance: MHD Pro Tune, AR Downpipes, ER FMIC/CP, DCI, RB turbos and inlets, KW V2 coilovers, Fuel-It Stage 2 pump w Ported fuel rail, Mfactory LSD
