Old 10-02-2012, 05:42 PM
drivinfaster's Avatar
drivinfaster drivinfaster is online now
bimmerfest Supporting Member
Mein Auto: rescued bmw's
disconnect the vac feed to the booster, block it off, and see if vac increases. if it does, then suspect a leak.
if you have a vac pump, you could also use an adapter to fit the inlet, and then apply vacuum. if it holds, then no leak. if it does not hold, suspect a leak.
df
