Old 10-02-2012, 06:00 PM
dc_wright's Avatar
bimmerfest Supporting Member
Mein Auto: '96 328iC, '04 325Ci
Originally Posted by drivinfaster View Post
disconnect the vac feed to the booster, block it off, and see if vac increases. if it does, then suspect a leak.
if you have a vac pump, you could also use an adapter to fit the inlet, and then apply vacuum. if it holds, then no leak. if it does not hold, suspect a leak.
df
I probably wasn't clear in my OP. When I disconnect the vac feed to the booster I get 19". When I tee into the vac feed line so that it's connected to the manifold and the booster is when I get 17"-18".
I've got a mighty Vac and when I connect it to the booster hose I don't think I've been able to get the one way valve to open so I think I've only been testing the hose......I may just have to pump the crap out of it for a while to verify I've got it really evacuated.
'96 328iC "Marie"
