Old 10-03-2012, 05:57 AM
R&E R&E is offline
Mein Auto: '11 328i xDrive, '11 X3
I got the WeatherTech floor liners for all around. They are a perfect fit and even cover the hump between the back seats. My only issue is the cargo mat; fits great even in the side cut outs. Don't need it to cover into the cut out area (where the net is on the side by the rear lights). you have to remove the net so it fits in, then if you need to access the compartment underneath, you have to pull it out from under the net. After typing this, I will probably go out and just cut the piece out of the mat.
