Bimmerfest - BMW Forums - View Single Post - M54 Engine Oil Leak
Old 10-03-2012, 09:03 AM
Grouper Grouper is offline
Mein Auto: '04 530i
Originally Posted by QAfred View Post
Listen to Fast Bob here.....VCG leak is a symptom and not always due to dry VCG gasket in our cars. In many, many cases it is a sign that the pressures in your engine are high due to a malfunctioning Crankcase Ventilation Valve assembly....CVV- the root cause!
Change the valve if you never have, along with the two vent hoses and the drain hose that goes down to the oil dipstick tube.
Then change your leaking gaskets caused by this failure-which can also blow you OFHG, and/or oil pan gasket. The weakest link - usually VCG- is going to blow when CVV is inop.
Can anyone point me in the direction of a DIY for this fix. I think I will replace the above Before I get into my valve cover leak, But I dont have a clue what these parts look like, or where there located, or anything like that.....
Any help would be appreciated!
Thanks!
Alan
