10-04-2012, 06:50 AM
Josh
Mein Auto: 95 540i m sport
Originally Posted by snowsled7
You forgot checking the blinker fluid... Who told you the above procedure was a good idea? I wouldn't reccomend people do most of what you listed. Changing fluids and filters is one thing but some of your "flush" concoctions would never be run through my engine. Fan belt spray, seriously? I would go for fresh belts if needed but spray everywhere for good measure? Interesting.
The fact is, most BMW models come from the factory would pretty tight. Seeking more power without boost just moves the power up the rev range where it is generally of less use to you. If you want a faster car, buy a faster one. You will spend 2-3k and be sorry you did so. Pony up 5k for the turbo and you will be more than satisfied.
This...Also good luck finding an s38, you'd be better off finding an s50 or s52 (out of an e36 m3).
Sent from my SPH-M910
