Bimmerfest - BMW Forums - View Single Post - Pick up my first bmw
Old 10-04-2012, 08:59 PM
paperplane94 paperplane94 is offline
Mein Auto: 1989 525i M20B25
Originally Posted by Sbrodacz View Post
Hi everyone,
I picked up my first bmw this past Tuesday. It's a 95 530i 5sp black on black with 96000 miles. This car is just amazing I am not sure I want to use it as a dd. It is in amazing shape. There are a few scratches here and there but nothing major and a farily easy fix. The driveside window goes off track. I was told theres a white piece of plastic that needs to be replaced. A $3 piece. I am not sure if this true or not. Also, the arm rest on the driverside is lose it just hangs done. Is this an easy fix?
These are what you need as far as the window sliders:
http://www.windowregulatorshop.co.uk...left-104-p.jpg
Nice thread here about the replacement procedure:
http://forums.bimmerforums.com/forum....php?t=1528586
To fix the armrest, there is a dowel that you must get to from the inside of the seat. It can be accessed through the back of the seat by removing the two screws on either side(they may have screwcovers on them).
The dowel is #5 in the pic below, it holds the armrest on:
you can use a center punch to remove the dowel.
OOOOH, this should help:
http://www.nmia.com/~dgnrg/page_34.htm
THen when you have it off you can either fix it or find a junkyard part.
