10-04-2012, 09:24 PM
D'oh, You kids!
Mein Auto: 1995 318is / 1993 325is
Originally Posted by Time2Fly
True but when you introduce spacers your wheels are no longer hubcentric...
:massive facepalm: WRONG. What do you think a hubcentric spacers is, anyway? IT IS STILL HUBCENTRIC! If it's made correctly, it will still result in a wheel perfectly centered on the hub
Originally Posted by Eight Thirty
this is so incorrect........
i dont understand how people dont get this.
Neither do I. It's about as simple a concept as there can be.
If your putting your wheel on your hub... which makes your wheel hub centric right? no disagreeing that?
now.... you take your brake rotor and you make it farther out 1 inch. (lengths differing on spacer sizes... and you put the correct bolts on.
Assuming it is a CORRECT wheel spacer (meaning hub centric) it will STILL be hub centric with very little/no weight on the bolts.
Exactly.
Quotes to live by:
Ken Kanne, Silverhill, AL, Honorary Forum Grandpa/Craigslist addict/Hoarder of all sorts of stuff
BMW-CCA #441426
1995 318is "Bebe"; 1993 325is "Elvira" 1985 635CSi "Katja" 1984 633CSi "Sylvia"
I NEED A NAP, DANG IT!
