Old 10-04-2012, 10:41 PM
hornhospital's Avatar
D'oh, You Kids!
Mein Auto: E24x2,E36x2,E30x1, F150
I am absolutely certain the case isn't supposed to be hot. It's either connected backwards or it has no ground and you are getting arcing to ground when you bump it against a chassis part. If it were connected backwards it would run backwards, and would blow a fuse when you grounded the motor case. Since it hasn't blown a fuse, it tells me your - (minus) side of the motor isn't connected to a ground.
Quotes to live by:
Ken Kanne, Silverhill, AL, E36 & New Member Intro Forum Mod/Bimmerfest Misplaced-Posting Tow Truck
BMW-CCA #441426 Which is worse, ignorance or apathy? I don't know, and I don't care!
1995 318is "Bebe"; 1993 325is "Elvira"; 1985 635CSi "Katja"; 1984 633CSi "Sylvia"; 1987 325is "Odette"
