Bimmerfest - BMW Forums - View Single Post - E34 535i transmission problems
Old 10-06-2012, 04:24 AM
Banned
Mein Auto: car
Originally Posted by BlueAngel M3 View Post
ok, thank u
Transmission gaskets do not leak after just one year if they were done properly. Obviously, the reason why you had been losing oil was because of this leak. Why did you check for a leak ? Did you spot an oil patch, or did you just happen to check the dipstick, and then notice that you were low ? Or did you experience any transmission problems ?
Did you top up enough transmission oil ?
You should go back to the shop that did it. It doesn't matter it if was a year. They are liable due to the nature of the repair.
