1995 BMW 525i auto trans selector heat seizure
Thanks for the prompt reply.
The linkage is clear of obstructions, in fact I disconnected the linkage from the gearbox end and the selector moved freely. After I replaced it the selector moved freely as before because the transmission was cold. After a 3 mile drive the whole thing had almost completely jammed. On removing the linkage again it all freed up until I re-connected it again. The fault is obviously in the box, maybe with an oil cooler or thermostat if fitted. If there is a cooler and stat could you please tell me where they are located. Many thanks.
