Thanks, So far it's a blast.
One of the keys that came with the car may have a bad battery or transponder. After some searching on the forums I cleaned up the key with contact cleaner and I'll see if it starts to take a charge at all. 45 min one way commute so hopefully I can kind of judge if it's going to charge by the weekend. (wife took the car today with the other key that works)
Update!-
Never mind I drove the X3 to work today and when I got out I was able to lock the door with the key button. Cleaning the key seems to have helped do the trick. Also on a side note- Best drive to work ever. Sure the 07 Mazda 3S I usually drive is fun but this is a whole different level :-)
Reason: update
