Old 10-08-2012, 05:14 PM
kskane's Avatar
kskane kskane is offline
From DownUnder
Mein Auto: '04 525i M54 with 6HP19Z
Originally Posted by mr.miriclewhip View Post
kskane did you only change your valve cover gasket? or did you also change your cvv? i have the same exact problem. my pictures even match your first two in the first post. i had the valve cover gasket replaced less then twenty thousand miles ago. and was just about to change the cvv, but was curious if maybe its more so the gasket. was going to still change the cvv but would rather knock two birds with one stone.
mr.miriclewhip, sorry for the late response, I first changed the OFHG, and then the VCG. I still have the leak in the second image which is from oil sump. I have not done any replacement of CVV, but guess I will be looking at that next (although, my breather hose that goes into the dipstick was recently replaced before i started all this DIY).
