Bimmerfest - BMW Forums - View Single Post - Power Steering hoses - which is pressure hose
Old 10-09-2012, 03:44 PM
jsaklas jsaklas is offline
Mein Auto: 323i
Power Steering Hose connections
I've removed the four hoses and have started installing the new ones. This has generated some questions:
1. The rack to cooling coil line is attached to the wheel well with two plastic ties. How was I supposed to "untie" them (The hose could not be removed without unfastening them.) and how do I reattach the new hose to the wheel well? (I had to partially cut the fastener.)
2. I connected the end of the high pressure line that attaches with the hollow bolt with no problem, but is the other end that goes into the P/S pump supposed to be forced in? It look like it is supposed to "pop" to seat properly. If I just "gently" put it in and then tighten the nut, the nut does not seat against the pump.
