Bimmerfest - BMW Forums - View Single Post - How do I use the Memory Seat functions??
Old 10-10-2012, 12:38 PM
ssjkev16 ssjkev16 is offline
Mein Auto: 2004 BMW 545i
Originally Posted by Gilgorm View Post
As noted above each key contains different stored memory data for the seat.
Does the Memory light come on (red) when you try setting the memory?
You can also turn off (uncheck) the "Last Seat Position" in iDrive so the seats won't respond when a different key is used.
no the "m" button does not light up when I press on it nor does it give any type of beep or anything, and yeah I have also done that too about the last seat position, but if its tied to the key it shouldn't be a problem as only the one key is being used at the moment no matter who drives the 5 (kept the other key locked away in case of any emergencies) ... its just really annoying how everytime the seats need to be readjusted and I can never get it feeling back to the same as the time before thanks to the wide array of settings available to be adjusted..
