Thread: Wake up!
Old 10-10-2012, 05:26 PM
BMWFatherFigure's Avatar
Old School
The injector clean would have saved the cost of a new set. Idle is poor most likely due to bad spray from injectors or low fuel pump pressure. Check them both and correct any faults. Then go for a long (local) drive to get things moving again. Gentle on brakes etc and keep speeds down. I suggest local only as you have to restore reliability - long walks should be reserved for sunset beaches!
Current:
E38 Parts Car
Previous:
