On an overhead cam engine the lobe on the cam for the valve that you are adjusting should be pointing up. The valve must be completely closed to adjust it.You will have to keep turning the engine over by hand each time you move to a different valve but at least will can get it done . I mark mine with chalk on a paint stick as I go so that I know what I have adjusted.
