10-11-2012, 06:07 PM
Mein Auto: .
Originally Posted by bmw330ci04
will do, thanks. just to clarify, when i do check it stone cold, if the oil is between the two notches, then im good to go, right?
and unfortunately no i dont have a Mity-Vac, though that probably would be a good investment
If you are worried about it, might be an idea to pull the filter and replace it. The soaked filter that you will remove will pull maybe a quarter or half quart of oil out.
But yeah, as Fast Bob says check it in the morning and see.
